close
Bt sport logging problems.
Jajo1
Upgraded phone on 14th Sept.with Bt sport as benefit. Received link by text and registered.Downloaded the app and tried to log in but error ID300 say can't find bt account. Tried phoning 150 but the choices don't cover queries and was just sent a text about bt sport which was useless. Was told would receive activation email but could take 24 hrs  but  not received anything. Can you help please?
@Jajo1  The ID003 error is an account Association error.   Have you had a look at THIS  ?  Have you tried using the link within that webpage ?
Yes,I went on the website and changed password to make sure I used the right one.Then I tried log in on the app but that's when it said they couldn't find the account.
Christopher_G
Hi @Jajo1
Welcome to the community.
If you follow the options for technical support on 150, someone should be able to help you with this.
Let us know how you get on.
Thank you. Contacted Tech Support and it took a while but it is now OK.
Jon_K
Former EE Employee
Thanks for letting us know you got this sorted, @Jajo1 🙂
