close
Broadband Service Issue in Wallingford
5a1eek
I’ve been having broadband issues since Wednesday 8th December:
1. Restarted at least twice on Wednesday
2. Restarted at least twice today
anybody know what’s happening?
BB issues are rarely localised but are more likely to be an issue with your own connection.
What do you mean by "restarted"? What restarted, the BB as a whole or just the WiFi? Did the router reboot?
1. Post your full router stats:
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
2. Try a wired speedtest, using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
3. What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker, not the Postcode Checker.
