close
Asda changing from EE, can I switch PAYG number to EE proper??
Basil21
I have very happily been PAYG with Asda on the EE backbone. Now they are changing to Vodaphone. I live out in the sticks n Shropshire and last time I had people round on Vodaphone they couldn't get a signal indoors. I don't want to experiment seeing if it's OK now. Can I retain my Asda PAYG phone number and transfer it to EE "proper" and be confident the signal will remain as it is now on my still EE connected Asda service? If so,  how do i transfer the number please? Thanks.,
EssexBoyEE
Yes, yes and yes.
Get a free PAYG SIM from EE,
https://shop.ee.co.uk/price-plans/free-sim
Credit your EE SIM, and if you wish check the Coverage etc, so your happy with everything,
Ask Asda Mobile for your Pac Code,
https://mobile.asda.com/help/transferring-your-number/PAC-request#:~:text=-%20The%20simplest%20and%2....
With your Pac Code Transfer your Old Asda Number to your New EE SIM.
https://ee.co.uk/help/help-new/getting-started-and-upgrading/keep-my-number/how-do-i-transfer-my-num...
Job done.
EssexBoyEE
Yes, yes and yes.
Job done.
Basil21
Thanks for the detailed and very helpful reply, I have ordered a SIM card on line and await its arrival, have a good weekend.
Leanne_T
Glad you got the help you needed @Basil21
You can find details on transferring your number in our How do I transfer my number to EE? Help page.
Thanks 🙂
@Basil21
Your more than welcome my friend, glad I could be of help.
And may I be the first to say 'Welcome to EE'
