Add-ons
Yanmize
I have been tryin to add some extra data to my plan and it keeps on saying technical issues. My data is running out and I'm currently not in a place with WiFi so I need the extra data ASAP! What can I do?
Christopher_G
Hi @Yanmize
Have you managed to get sorted? Does your device show a good signal?
Are you trying to add it through the add-on portal?
Its Still not adding it. Saying technical issues and all.
The signal is strong and good.
Yup, trying to add it through the add-on portal.
Christopher_G
OK thank you, @Yanmize
I recommend speaking to our Mobile Care team on 150 so that they can look into why this is happening and get the data added on for you.
