close
5GEE WIFI TECHNICAL SPECS!
essojay
Is anyone familiar with the technical specification of the 5GEE WIFI devices
Specs like:
1, Maximum 5G speed capability
2, 5G Band and support for mmWave
3, 4G CAT  LTE-CA  the CAT number
4, 4G Band
5, Manufacturer etc
6, Support for RNDIS on the Type-C port
...etc
Leanne_T
Hi there @essojay
Our EE Shop page shows information on the device,  if you select the device and then Tech Specs 🙂
Another user on the community may know the other information you have requested 🙂
Thanks.
EE are weak at publishing specs at the level you are asking. You mostly get physical dimensions & weight.
Your best bet is id'ing the manufacturer & GIYF.
