close
4Gee router not recognising password
shamlin50
Trying to set up my 4Gee router and its not recognising the password on the back of the router, have managed to connect laptop using wps button but cant connect anything else.
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the password found under the battery cover. Then on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
Unable to log in to  the address you gave as  not recognized, no password under battery cover.
Christopher_G
Hi @shamlin50
The link works OK for me. If you're able to get onto it now, try admin/admin as @XRaySpeX suggested.
