close
4GEE WiFi mini new menu is cr*p
Jax49
I believe in the saying "if its not broke, dont fix it".
So what have you done to the 4GEE WiFi mini menu?
Why can't I send texts? Where is the easy to use layout?
This new one is c***. Loads of options are missing or hard to find.
How do I get the old menu back?
@Jax49   So you don’t believe in updates ?  Would you say the same about your phone/tablet/PC.  ?
What's changed in the menu? Post an image of it.
The SMS inbox should under Status.
Updates are fine when needed. But totally redesigning the menu, removing options and making others hard to find is not an update.
SMS inbox is still there, but sending an SMS has been removed. This means I have to remove the SIM and put it in a phone to use texts.
Yes, it appears now that you can only send SMS (as a reply) to nos. that have previously sent to you.
