close
4GEE WIFI mini
Momac75
I have charged my wifi mini and am trying to connect a device to it. It says that I have the wrong password and doesn't connect. How can I fix this problem
Northerner
Hi @Momac75
You need to enter the correct password on your device. The password will be on a card or sticker on your WiFi mini.
I'll assume you mean the WiFi pwd. Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the password found under the battery cover. Then on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
