close
4G tp-link won’t connect abroad
Ry45
Hi - has anyone been able to solve the issue of the tp-link 4g WiFi working while abroad? It works seamlessly in the UK but I am unable to connect while I am in Greece.
*I have turned on roaming
*I have reset the device
*I have active data available (via a top up sim)
not sure what else to try as it shows full connection on the device but nothing loads when connected to it.
Mustrum
What model, where did you get it, is it locked to a UK mobile provider?
So many questions, what sim are you using, which provider?
