close
4G router password not working
KanesNana
My 4GEE router will only connect to my work laptop when I press the button on the top. When I try the password on my tablet or kindle it says invalid password. I tried pushing a paperclip into the reset hole at the back and I tried connecting using the ethernet cable that came with the router but no success - please help
thanks
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the password found under the battery cover. Then on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you wish..
I logged in using the details on the sticker on the back of the router http://192.168.8.1 web password and changed the password but the changed password does not connect. I can't log back in because none of the passwords are connecting. Any ideas? thanks
Factory Reset it.
