close
4G on pay as you go phone
jw60
My phone if 4G enabled and I've checked the settings are correct but I can't use the internet away from home. It's been suggested that I need to get an updated sim card for it to work. Is that correct?
Jon_K
Former EE Employee
Thanks @jw60.
I'd recommend contacting our Tech Care team so they can check that your account is set up correctly.
They will also be able to continue troubleshooting with you.
Jon
11 REPLIES 11
Hi @jw60
No, it almost certainly isn't correct. What phone do you have and do you have credit on it?
It could be as simple as enabling mobile data on your phone.
It's a HOMTOM HT26 and yes there is credit on it
Katie_B
Hi @jw60
What reports back to you when you text AL to 150?
Katie
Hi Katie,
It just gives me details of my balance and last top-up info
Jon_K
Former EE Employee
Hi @jw60.
Does it give details of any available data?
Is mobile data enabled in your phone settings?
Could you try restarting your phone again?
Jon
jw60
There was no mention of data on there.
Found cellular data, switched it on. Restarted the phone but still not seeing 4G on the top line of the phone display. Sent AL again to 150 and same reply as yesterday, no mention of data
Jon_K
Former EE Employee
Thanks @jw60.
So cellular data is now turned on?
Do you have another phone you could try your SIM card in?
Jon
jw60
Yes cellular data is switched on. Unfortunately I don't have an old one that's 4G enabled.
Thanks for your help
Jon_K
Former EE Employee
Thanks @jw60.
Jon
