on 16-07-2020 08:52 PM
Good evening
I have had the above box for 2 years and no problem. I have started using it in a remote building to connect to security cameras. The Wifi box is connected to a 12V 120AH deep cycle battery.
My first question is how long will the battery power the device before draining. (How many amps does the mini wifi draw?)
2nd question it charged by a permanent connection to the 12v battery but the mini wifi runs out of power every 24hrs. Is this device faulty?
on 17-07-2020 09:18 AM
Welcome to the community.
Do you get a good signal on the device? Poor/fluctuating signal can affect battery life.
How long did the battery last in the old location?
on 17-07-2020 07:34 PM
Yes I get a good signal line of sight vue to the nearest mast. Battery life was typically 4-5 hours.
The mini wifi box has a permanent feed to it from the 12v battery!! But seems to die after 24 hours??
Please can somebody help me
on 18-07-2020 10:10 AM
Hi @PeperRustler67.
Does the power battery run out too?
Does it run our completely, or go into stand-by?
Jon
on 18-07-2020 07:50 PM
on 19-07-2020 10:35 AM
Thanks for coming back to us.
I would suggest getting in touch with our Tech Gurus, they will be able to run through some troubleshooting with you and let you know if the device is faulty.
Let me know how you get on.
