iPhone 15 Bluetooth problem
Stevo5171
I recently purchased 2 new iPhone 15 phones and since using them I can’t get a connection to any Bluetooth device ? Hands free vehicle devices etc
Alex_H
Hi @Stevo5171,
Welcome to the EE Community
Are the phones finding the available bluetooth connection if so what happens when you try and connect?
Are both phones on the latest software via Settings> General> Software update?
When having any type of connection issues, including with Bluetooth, a reset of the network settings of the phone may help resolve. This will delete WiFi settings as well though so make sure you have any passwords handy you need, but this would be done via Settings> General> Transfer or reset iPhone> Reset> Reset network settings
Alex
Done everything mentioned in your reply still no joy could there be a fault with the iPhone 15 ? If so do I take it to my local EE shop or do I go to Apple Store ? I need it fixed asap as I need to pair it with an hearing aid
@neil7171   Go to the Apple Store if you can.  You’ll need to book an appointment through.   Also take with you any information you have about the hearing aid.
You might want to read THIS  first though
KawaiiBean
I’m having the same issue
Leanne_T
Hi @KawaiiBean
Welcome to the community.
Are you unable to connect to any other device using Bluetooth, or is this one particular device? Do you get an error when trying to connect?
Also, have you been able to connect previously?
The If you can't connect a Bluetooth accessory to your iPhone or iPad – Apple Support page has some helpful tips to try 🙂
Speak soon.
