Sim either not being recognised or not working properly
C_Carr
Got a new sim which worked fine for a couple months, now my phone only recognises it intermittently, sometimes I’ll turn it on and it’ll work for 5 minutes and then act as if the sims dead, it’ll normally recognise there’s a sim in the phone but will act as if it’s blank, no service whatsoever and my phone number also disappears from iPhone menus etc (iPhone 13)
Christopher_G
OK, thanks for letting me know, @C_Carr
They should be able to help sort this out in-store. I suggest taking in some photo ID, in case they need to replace the SIM again.
Let us know how you get on please.
7 REPLIES 7
@C_Carr  Sounds like a faulty sim,  can you try that sim in a different phone ?  If it works ok in that device then it’s probably the phone that has the issue with the sim contacts.
Yea done some digging and I think it’s common with iPhone 13’s actually, will take it in to EE see if they can sort it maybe. Weird because I managed to change it to an E sim before it disappeared again and I’ve still got no service which makes me think it’s not the SIM card reader that’s broken. So yea maybe a dodgy sim. Thanks for the response
@C_Carr  if you’re using the eSIM and it’s nothing to do with the SIM card.    Have you tried a network reset on the device?
Sadly yes, will try that again though can’t hurt I guess
Christopher_G
Hi @C_Carr
Did the network reset improve things for you?
No, going in to EE today to try and sort a new sim
Christopher_G
