Can’t see reference numbers
Jasvinders
I ordered iphone 17 pro max
and it doesn’t show me the reference number and not even getting any mail.
Chris_S
Our contact centre team would be best placed to help you @Jasvinders, so I'd recommend giving them a call again, and a guide can take some details from you and check our system for your order.
Chris S
7 REPLIES 7
Ayman11
When did you order. I have also ordered and was told i will get it in 2 weeks but it has already been more than 3
I ordered it today
Chris_S
Hi @Jasvinders
The confirmation email may have gone into your email provider's spam quarantine folder.
Could you try checking your spam folder please?
Chris S
Hey
Yes i have checked the spam folder but haven’t got any reference number or
email from EE
If you send it it would be helpful for me
Thank you
Chris_S
Thanks for checking @Jasvinders.
Although we don't have access to EE systems here in the EE Community, if you give us a call, a guide will be able to take your details and give you an update.
Chris S
I have called them but haven’t got any solution ftom them
Chris_S
Chris S
