Roaming
Wom2
I’m in France and trying to set up a roaming abroad pass, every time I text YES to 150 , the message fails
Wom2
I am abroad in France and unable to send texts or make calls
Pilot222
It might be because you don’t have any spend cap, I’m not an expert alas EE has become very difficult to contact a live person. If u have someone in uk that can ring them on 07953 966250 that might help. Good luck or have u got the settings on the right thing for Europe?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
