How do I delete a voicemail message on iPhone 12 Pro without reading it
Sirrah
Hi
ive received a voicemail message from abroad and if I open it to listen to it I will be charged quite a bit. How do I delete it
@Sirrah   Your not charged to listen to a voicemail if you’re in the UK.    What makes you think you’ll be charged?
