Visual voicemail not working iPhone 12
HilsR
Received text for set up and pin. Added greeting. Switched phone on / off. Anything ekes I need to do as it is not working?
Leanne_T
Hi @HilsR
Thanks for coming here.
What happens when someone calls and leaves you a voicemail?
If you tap the voicemail icon do you see all your voicemails as a list on your screen?
@HilsR  Have you texted IPHONE VISUAL  to 150 ? this will turn on visual voicemail
Yes. Txt to 150. Txt back says set up with a PIN number.
I don’t know what else to do other than find the time to contact EE direct.
Thanks for reply
Leanne_T
Hi @HilsR
If this is not working for you, please give us a call on 150 and the team will be happy to help you get this sorted 🙂
Leanne_T
Thanks for sharing @Willy121DC
Leanne 🙂
