Can't activate visual voicemail
pwalk
I'm using a Samsung Galaxy A54. I activated visual voicemail by texting VISUAL to 150 as per the instructions, and got a text back after a while confirming it's ready to use. But I still can't toggle the visual voicemail setting on in the phone app (I use Google Phone). My software is up to date (in fact, it updated to the latest OneUI 8.5 last night) and I've restarted the phone, but no joy. Still can't turn the feature on. 🤔
13 REPLIES 13
Northerner
Hi @pwalk
Try restarting your device.
It can take 24 hours to activate but on my Samsung it was a few minutes.
pwalk
Thanks @Northerner ,
I did restart after receiving the confirmation text (which arrived about 10 hours after the VISUAL request).
I'll wait a bit more and see.
Northerner
Hi @pwalk
Try texting visual to 150 again.
This is odd. Try clearing Google phone cache. It might only work on the Samsung call app.
pwalk
I deactivated and reactivated the voicemail, also (as suggested by AI) with wifi turned off, cleared phone app cache, restarted etc - the setting still refuses to turn on. Looks like something is stuck at EE's end. I could call customer service but can't really be bothered, I only wanted to test the visual voicemail, but shame it doesn't seem to work out of the box as it should.
Northerner
Hi @pwalk
Does it work on the Samsung call app
pwalk
Hi @Northerner ,
Strangely, the Samsung Call app doesn't seem to have a visual voicemail option at all in the voicemail settings.
Northerner
Hi @pwalk
Try updating in the galaxy store.
You're definitely running Android 16?
pwalk
Hi @Northerner ,
Yes, Android 16 / OneUI 8.5 and latest versions of both phone apps.
gaz2023
Hi @pwalk ,
Try texting 'Visual ON' to 150 and see if that activates it.  Then once you have the message back to say its either already activated or now activated, check the 'Visual Voicemail' setting with the Phone App. See below:
Further details under the Samsung section on Visual Voicemail | Mobile Help | EE
