02-09-2024 05:22 PM
02-09-2024 05:55 PM
There is no account access on these forums, you'll need to speak to EE CS on 150.
Mac books are here: https://store.ee.co.uk/brands/apple-336/laptops-and-tablets,macbook/15077
02-09-2024 06:55 PM
Hi, thanks for your reply!
I have already contacted EE customer service and the sales team! I’ve explained in the original post what the outcome was.
I’m just now left in limbo in regards what I’m supposed to do?
Thank you
02-09-2024 07:16 PM
If your order generated an order number starting with "SO" then your purchase is through EE Store (formerly BT Shop) which has it's own support method via email at enquire-store@ee.co.uk.
Check the link for a breakdown of the different contact methods for different types of orders: https://ee.co.uk/help/orders/consumer-electronics
Beyond that there is Order Tracking built into the App for certain products ordered directly.
As they are not a "Connected Product" (the kind that usually generates an XKO number or is added to your mobile bill) regular EE CS would not be aware of the order.
