04-01-2023 02:02 PM
Battery usage is really high, mainly in the background. Anyone else seeing this?
Approx 33% in last 24 hours.
20-07-2024 06:30 PM
Did this ever get fixed as I have the same problem 33% usage per day battery needs charged a couple of times a day now
13-08-2024 03:58 PM
Hi. Yes I’m getting the same. I’ve even tried to force close it but it’s still using the same 33%
13-08-2024 03:59 PM
Yep just replied to you earlier
13-08-2024 04:00 PM
But can we stop it running in the background
13-08-2024 05:15 PM
Hi @Rob62
Have you recently downloaded the Cyber Security app?
Speak soon.
13-08-2024 06:08 PM
Yes I have Leanne. Just spoken to technical support and basically until they sort it out they said it will use a lot of battery so uninstall they app so I have and cancelled the trial
