Apple Watch data plan issues
angwyn
Every time I change my iPhone or have to unpair and repair my Apple Watch for whatever reason, I always have to spend hours on the phone to EE (usually multiple phone calls and scheduled callbacks with other teams) as there is an issue with the Apple Watch eSim or a problem with EE's systems and the process for getting the data plan configured so the Apple Watch accepts it and the data plan can be used.
This is wholly unacceptable. Today will be, I think, the third time I have gone through the tedious process of speaking to EE's technical support team about Apple Watch data plan issues. I am expecting a scheduled call at 5pm from EE after spending an hour on the phone yesterday.
The process goes something like this:
  1. The Apple Watch data plan (which is active) cannot be added to the Apple Watch, despite it being the same Apple Watch (and obviously retaining the same EID number).
  2. Step 1 fails and I am prompted to call EE on 150 and relay a 3-digit code.
  3. I call EE, explain the issue and relay the 3-digit code.
  4. The Level 1 technical support team cannot resolve the issue (in the past there was mention about duplicate Apple Watch profiles on EE's systems – whatever that means).
  5. I get passed to Level 2 technical support who try various things but usually replace the eSim in the end. I am told this takes 24 hours to active. They schedule a callback with me, meaning I have to set aside further time to take that call.
  6. The issue still persists but eventually something is done that fixes it. I am not told the root of the problem so when this cycles starts again I am not able to truncate it and get straight to the solution.
Previously, I ended up with 2 Apple Watch data plans and had to request the duplicate plan be cancelled and had to wait for a refund of unnecessary monies paid.
It has been like this, to my knowledge for at least 3 years. It is unacceptable that any paying customer has to go through the cycle I outlined above once, let alone three times. If it is a case that there are issues with Apple Watch eSim provisioning, and/or EE's processes need to be aligned with Apple's, that is frankly a matter for EE and not my concern.
If EE intends to hold itself out as the UK's best network for Apple devices, then it needs to live up to that. I'll be changing to the iPhone 14 when it is released in September but cannot face going through this for the fourth time, so will likely move away from EE.
P.S. I would be grateful if EE staff on this forum would not suggest I contact support, as I have already done so multiple times over the course of the last few years. Time would be better spent flagging this issue higher up, which, upon cursory glance of the forum is not isolated to my account.
17 REPLIES 17
Sean_Jennings
EE support for this seems to have deteriorated.
Two years ago I got a replacement Apple Watch after the battery swelled on the previous. I went through the Watch App on my phone, got a 3 digit code, phoned EE and they switched the data plan from my defunct watch to my new one within 10mins…
Last week I bought an Apple Watch Ultra. So far I’ve had two phones call a to Level 2 tech support each lasting 45 mins, plus a visit to an EE shop scheduled by tech support and a 30 min phone call there. Still not working.
After 30 years of being an EE customer I’m thinking of switching mobile supplier…
@Sean_Jennings , did you make sure that you removed the previous watch before trying to add the new one and then make sure that both the phone and watch are on cellular before adding the data which should then connect it with data.
No because…
(a) that wasn’t necessary when I successfully replaced my original S4 watch with a replacement S4 after the battery in the first swelled after 3 years
(b) neither the setup screens or EE Tech Support suggested doing this.
It’s not just the plan that isn’t working, in other words neither cellular nor data are working.
Linzi_H
Hi @Sean_Jennings
I'm really disappointed to hear that your watch setup hasn't gone smoothly. When these things happen I know how frustrating it can be.
I'm sorry we've left you feeling unsupported with your query, but I'm confident this will get resolved.
If you're speaking with our level 2 team, they are the right area to get this all sorted out for you.
Linzi
I’ve spent two hours talking to your Level 2 team and they haven’t been able to resolve things. Thats billable time that instead of earning income I'm having to spend talking to EE. I can only hope you have a Level 3 or 4 team…
In the meantime I’m polling my followers as to whether there is a better mobile supplier for iPhone and Apple Watch support.
MillyC619
I have recently added an iwatch to my mobile account for my husband. I was told that the GPS/cellular element will still work with his mobile (we’re both on EE) but we are struggling with getting the data plan to activate and getting an error code.
is there a way he can have the iwatch and plan when it is attached to my account?
really stuck!!
Linzi_H
Hi @MillyC619
Thanks for coming to the community 😊
Your husband should still be able to use the watch if you've set this up with a family plan on your account, even if his phone is on a separate account altogether.
If you're still getting an error code after trying to set this up, please give our team a call on 150 from an EE mobile or 07953 966 150 from any other phone.
I'm really confident we can get this all sorted out!
Linzi
As someone who works in this field and sets up 100’s of Apple Watches a month I can assure you that this is an EE problem and not user error as you seem to think. Setting up an existing EE cellular plan on an Apple Watch is a very poor experience for most people on EE. I myself have had the issue on every device since the series 5. Going from ultra to ultra 2 was by far the worst!
