like the Samsung s24fe and Samsung a55
wakka80
I like the Samsung s24fe and Samsung a55 and don't know which one to upgrade to.
Leanne_T
Hi there @wakka80
If you order online with us or over the phone on 150, you can return the device if you decide this is not the one you would like.
Details can be found in the Returning a device or SIM within 14 days page.
I hope you love the one you decide to order 🙂
9 REPLIES 9
@wakka80  Only you can decide which one you want as you’re the one is going to be using it.
wakka80
very true Chris both very similar phone's
Leanne_T
Hi there @wakka80
wakka80
probably will pop into a store to look at both devices, I think
Leanne_T
No problem @wakka80
Just for awareness, if you order in store, they have no change of mind returns.
The Help page has full information for you 🙂
Thanks.
wakka80
thanks just a bit difficult to order online as I work shifts so not always at home, unless can get phone delivered to a ee shop
Katie_B
Hi @wakka80
You can order online and select your local store for delivery.
Hope this helps,
Katie
wakka80
thanks Katie I have a smart watch with my current phone would I still able to upgrade
Katie_B
Hi @wakka80
If you upgrade your phone, it won't affect any other contracts on your account.
Katie 🙂
