Unlocking a device
Floresque
Hi everyone - I have a Samsung device that is locked.  I started the unlocking process by pressing *#06#  to find my IMEI number which I then verified on the form.  I was then taken to a screen which gave me my unlock code which I  was told to keep handy as I would "need it for the next bit"
I was asked to "Hit the link below. We’ll explain how to use your unlock code to finish things up"
Unlock your Samsung device
That link takes me back to the screen with instructions on how to retrieve and verify my IMEI number which I have already done - if I try to repeat those steps I get this message
I then entered my email address to have "the steps to unlock your device" sent to me by email.  The email says my unlock request has been accepted and shows my IMEI device number but there are some simple steps I need to complete on the device itself before I can use it on any UK network".  There is also a link.  Great - now I'm getting somewhere - the link takes me to this page:
https://ee.co.uk/help/mobile/manage-use/unlock-device/unlock-an-ee-device-to-use-with-another-networ...
There are no further instructions to unlock my device or how to use the unlock code I was given - which is different to the device's IMEI number.  The two links on the page to unlock my device take me back AGAIN to the IMEI retrieval and verification page which I have already done and tried to repeat.  After an hour of going round in circles I've given up.
Can anyone help me please?
43 REPLIES 43
DalM
Yes you are emailed a 16 digit code in which you insert sim of different unsupported network and it will ask you for the unlock code type in only the first eight digits and impress unlock on the next screen you typing the last eight digits and press unlock
Your response contradicts what others have said, that you use the latter 8 digits first, then the first 8.
Is this what your meant?
Starbaratwill90
I want unlocked my ee phone and sim so I buy shopping on vocher plz  thank you
@Starbaratwill90 : You can just apply for unlocking by using the Unlocking your device form and giving its IMEI no., which you can obtain be dialling *#06# into its keypad.
However I don't see how unlocking your phone would let you do any more shopping than you can now.
