Pixel 8/pro
baldi87
Valued Contributor
Valued Contributor
Do you have any info about pixel 8 serie coming to ee?  Usually with iPhone they advertise is ages before launch but cant find any info about new pixel.
11 REPLIES 11
I just went to bills section and it says upgrade available .... as said i was holding off for a few months for the p8pro,  it took me to the shop, i then clicked display google only and the pixel 8 and 8 pro are there for pre-order 👍🏻
I visited my local EE store yesterday as I was due an upgrade from my Pixel 6 Pro, and placed a pre-order for the Pixel 8 Pro which will arrive into stock on the 12th, the free Google Watch 2 can then be claimed between October 27th and to November 29th.
Online only shows the Flex Pay options, but I get 20% discount codes through my employer which only applies to the airtime on the Flex option, it's worth visiting the store as they can usually offer some form of discount if you're not afraid to barter.
