Pixel 10 Pro Esim
MikeP9
Hello, I currently have an Esim with another provider, but want to join EE with on a Esim, so I have two Esim one with EE and one with the other provider, is this possible?
Schockwave
@MikeP9 , it looks like it is only in the USA, but here you would need a physical sim + ESIM, check here for full specifications:
https://www.gsmarena.com/google_pixel_10_pro_5g-13987.php
@MikeP9  Yes you can provided you take out a contract with EE, and your device supports multiple eSims,  Obviously this EE contract will have its own number as you can not have one number across two sims. If I’m correct they’ll not both work at the same time as you can only use one eSIM at a time so you’ll have to switch between them.
thanks so if i wanted to use both at once I best with a physical and an esim?
Ali_A
@MikeP9
Depending on what your device allows, you can either use 2 eSIMs or 1 eSIM and 1 Physical SIM.
It doesn't matter which combination, the device will still allow you to use both SIMs at the same.
You can manage the SIMs and switch them on and off independently if desired, in the settings.
Ali
Hi @Ali_A  its a Pixel 10 pro i can find evidence that it supports two esims at once in the states but cant find anything in the uk version, do you know if it does?
Schockwave
