Notification problem, I don't receive any notifications
Andy713
I am having notification problems, I am not getting notified about any texts or WhatsApp messages I receive.I have tried all the obvious techniques and can't find any other way of sorting it.
18 REPLIES 18
Can you be more specific on what "all the obvious techniques" are, that you've tried so far?
Are you using Android or Apple?
When did you last receive any notifications?
I'm not receiving any notifications from my Motorola g50.EE had a service
problem which they have now fixed, Would me not receiving any
notifications, But if I go into text messages a message is there, Same
thing with WhatsApp.
@Andy713  Is notifications enabled for those apps ?    Is a do not disturb option enabled?
On an Android phone, following Settings > Notifications > App notifications
Ensure the apps you have issues with, have notifications enabled.
Yes,It is.
Lesley_W
Hi @Andy713
Thanks for coming to our community.
Were you able to check the do not disturb option that @Chris_B suggested?
Lesley
Hi Lesley,Yes I did check it and that was turned on.
I don't think a DND stops notifications. It just makes them silent.
Lesley_W
Thanks for checking that @Andy713
Have you turned that off now? Are notifications coming through?
Lesley
