My son's tablet has stoped seeing my WiFi
tracer237
Both my son's tablets have stoped seeing my WiFi network but see other neighbors including EE.
Other devices are ok, after changing some settings on router.
All happened after power cut.
Any ideas?
7 REPLIES 7
On these tablets try Forgetting your router's WiFi network & then make the connection again.
Thanks for quick reply.
I tried that on both, and have tried searching for my home network but nothing. Still finding others, including EE from neighbours
Leanne_T
Hi @tracer237
Which device are you using?
Can any other devices connect to the WiFi?
Leanne 🙂
Hi Leanne,
They are android tablets.
Model N10-EEA.
Were working fine, a little slow on Roblox but fine otherwise.
Everything else has connected to WiFi fine.
Where had network saved, it was saying not in range, so got it to forget the WiFi, but it doesn't see it now.
I'm totally baffled. I thought it's the tablets, but they are seeing other networks Inc EE from other people.
@tracer237  Try turning the router off for 30+ seconds and then restart it and try connecting the devices again.
Thanks. Had tried that before but left it quite a while, cleared all saved networks. Turned tablets off, then restarted all with router first.
Happy to say both working now, and everything else still seems to be.
Thanks all for ideas and final solution
Christopher_G
Ah, that's great. Thanks for letting us know, @tracer237. 🙂
Enjoy the rest of your weekend.
