Moisture detected after phone update
Thor87
My phone updated last night, and instantly it said there was moisture detected in the charging port (phone has been bone dry before and after the update), and is still doing this everytime I plug it in.
Tried turning off fast and super fast charging, no joy. Any ideas?
8 REPLIES 8
Christopher_G
Hi @Thor87
Welcome to the community.
Does this happen with more than one charger?
Northerner
Hi @Thor87
Have you made sure the port is clean.
I sometimes receive this message depending on the weather and how i have held the phone. If you can try clearing the phone cache.
DLJH1998
My phone has been doing the same and I am unable to charge it with wire. Checked for moisture and dirt and there's nothing
Katie_J
Hello @DLJH1998
Thanks for coming here.
Are you able to test another socket and charger?
Katie
 I've tried various wires and sockets. It seems to be random when it occurs and goes back to normal after a while.
For example, I was driving with my phone plugged into the car for android auto and was all working fine then it came up moisture detected when it hadn't been near any moisture.
This only started happening since inupdated my phone on the 27th June.
Christopher_G
Hi @DLJH1998
This can sometimes be caused by having a small amount of debris in the charging port. What kind of phone are you using?
I've checked and cleaned the usb port and used different wires and sockets. Samsung s22 ultra
Katie_J
Thanks for checking @DLJH1998
I would recommend speaking with our technical care team who can look into this further.
Are you aware if you still have warranty?
Katie
