Messenger stuck on "Waiting to connect"
happyhacker
A14 with payg EE. messenger stuck with that message. Tried all resets (cache, phone, etc.) and phone works for emails. Cannot send or receive texts but worked OK yesterday.
Northerner
Hi @happyhacker
Do you have sufficient credit.
Try restarting your device as well.
If other internet-based functions work, then your phone has a working internet connection.
That leaves an app-specific issue.
happyhacker
Yes! It turned out to be flight mode accidentally set!
Glad you got it sorted. But your first post mentioned that your phone's email program was still working. That would be impossible if flight mode was the fix for another app not working.
happyhacker
As soon as I turned it off 13 msgs arrived. I do remember being able to do other things but you have a point. I will check that out. Thanks.
