MCK code
BBlim
I just tried to enter an unlock code for several times after it failed to accept my unlock code... and ask to enter MCK code. What is the MCK code? thanks
89 REPLIES 89
Thanks, this works magic.
marcinch18
Trying to unlock my a71 thats locked on  ee ... tried too many times ... and now asking for Mck code. Can I get MCK code to unlock my device?
Leanne_T
Hi @marcinch18
Thanks for coming here.
Do you have the unlock code from us?
If so, have you tried this great advice from @Chris_B posted in this thread?
1. Retrieve the device lock code which EE gave you. It should be 16 numbers in length.
2. Enter the last 8 numbers (from the 16 digit number provided by EE).
3. Once you get past that screen, enter the first 8 numbers (from the 16 digit number provided by EE).
4. You should now be able to access the contents of your phone.
5. Restart your phone.
Leanne
I don't have the MCK code yet. How to request it?
Leanne_T
Morning @marcinch18
Please see my reply to your other post here - Re: MCK code - Page 6 - The EE Community
Leanne 🙂
@marcinch18 : You can just apply for your unlocking code by using the Unlocking your device form and giving its IMEI no., which you can obtain be dialling *#06# into its keypad. Then follow the instructions above for the MCK.
Hello
My wife has an EE device and used the EE unlock code but it did not work and instead blocked the passcode from being entered
now she requires an MCK code but can not get through on the phone please can you help
thanks
alan
Christopher_G
Hi @alangray47
I'm sorry to hear that. You'll need to speak to our Mobile Care team so that they can look into this for you.
Thanks a lot for the help,it has worked
Hi, please I'm trying to get MCK code too. I use Samsung note 10+.
Thank you.
