I restarted my phone its now asking for pin and puk number
LadyRed120
Help I restarted my phone its now asking for pin and puk number, only that memory is in my phone, why has this happened and how do I fix it?
The PIN is usually '1111'.
You'll find the PUK, to unblock your SIM after too many incorrect PIN attempts, in your online MyEE under Home > Plans & Subs > Unlock your SIM / eSIM.
QuantumEcho
You can usually find the PUK code on the card your SIM came with, or you can contact your carrier’s customer service to get it. Once you enter the PUK code, you should be able to set a new PIN and get back into your phone.
