Galaxy S22 Ultra USB connecting to computer issues
Dragon_
Skilled Contributor
Skilled Contributor
Hi.
I have just received my S22 Ultra and so far I am loving it, but I have an issue connecting it to my computer for file transfer.
I connect it the puter and it starts to charge, but that's it. There is no pop up asking what you want to do, No idea why or where to look for an answer..
Also, I want my home screens to carousel, but they don't.
Can anyone help with these issues?
Tracy
31 REPLIES 31
James_B
EE Community Manager
Hi @Dragon_,
Did you follow the settings @Northerner posted earlier in the conversation?
Dragon_
Skilled Contributor
Skilled Contributor
Hi.
Yes I have, many times. I do the notification in the noti area, but when I click on it, it takes me to the battery area. No pop-up ever..
James_B
Have you tried a different USB port on your PC @Dragon_?
Did you try @EssexBoyEE's tip of restarting your PC with the phone connected?
Dragon_
Skilled Contributor
Skilled Contributor
Yes, diff cables, diff ports, computer reboots, with and without phone attached. I even tried my other computer but get the same results.. It will charge only.
I've been on the live chat page all day today.. no 'start conversation' ever appearing. What's up with that? 😐
James_B
Hi @Dragon_,
I've just checked and the start conversation button is showing for me at ee.co.uk/contact-ee. If you're using a VPN you may need to turn it off to access live chat.
As a next step, I would recommend installing the required drivers manually from the Samsung website.
Dragon_
Skilled Contributor
Skilled Contributor
Hi
VPN has been off all day, no ad or pop up blockers even tried 3 different browsers... 😂
I've installed the Samsung drivers and reset the phone back to factory twice.
Many reboots of phone and pc. 3 diff cables, 2 USB ports, 2 computers.
All iterations and combinations of these things works with my Huawei Mate 20 Pro.
So I'm really at a loss now.
I tried calling EE but there is no troubleshooting option, (that I heard anyway).
I don't wan't to send this phone back..
☹️I will try to fugure it out over this evening.. Arghhhh
Hi @Dragon_
It goes into battery because you are pressing on the wrong option, you are pressing settings. You need to press the android system and it takes you into the USB options.
You said above that you've already synced with your PC when it worked. If that's the case your PC will ask how you want to manage your device and it's connected. All you need to do is connect the cable once your phone is unlocked.
Tbh if you are changing the settings in the hidden developers options then it maybe a setting you activated. Equally it maybe something on your PC which is the most likely issue.
Dragon_
Skilled Contributor
Skilled Contributor
Evening..
This is my notification area..
The only thing to click on is 'cable charging'.. which opens the battery page..
Unless I'm really dense and can't see what you are referring to? 🙂
@Dragon_
What developer setting have you changed?
The option isn't showing becase you cable isn't recognised make sure your port is clear of dirt and it's firmly connected, or:
  • Try another cable
  • Try another pc or port.
Dragon_
Skilled Contributor
Skilled Contributor
I've tried all those.. cables, ports and computers
Developer settings i changed was the Default USB config to Transferring files. Changed nothing else..
T
