20-06-2022 01:24 PM
Hi.
I have just received my S22 Ultra and so far I am loving it, but I have an issue connecting it to my computer for file transfer.
I connect it the puter and it starts to charge, but that's it. There is no pop up asking what you want to do, No idea why or where to look for an answer..
Also, I want my home screens to carousel, but they don't.
Can anyone help with these issues?
Tracy
20-06-2022 06:01 PM
H @Dragon_
I think I know what you mean. Two part answer. Currently you cannot have this option on your home screens (annoyingly) unless you use another launcher.
You can however have this option for your apps draw but you need to download Good Lock and then Home up from the galaxy store (not play store). You can then activate loop pages under home screen.
20-06-2022 06:11 PM
I give up!!
I must have clicked that 'cable charging' a hundred times since yesterday, And now it works.. It's connected to puter and file transfer in progress.. Thanks for everyones help!
Tracy
20-06-2022 06:22 PM
Hi again
I've installed Nova launcher, whilst it does exactly what I want to, it doesn't seem to like any other themes...
Life is so hard these days! 😂
Tracy
20-06-2022 07:05 PM
Hi @Dragon_
It's a bit strange how Samsung never implemented this feature without the Good Lock app. Seems like a sensible feature that is missing.
Installing another launcher will always give you plus and minus benefits.
20-06-2022 07:22 PM
The same thing happened with my Huawei a couple of months ago.. You could spin your screens all day long, then an update happened, and they stopped it..
Will definitely check Good Lock out.. Incidently, I was watching some YT vids last night and there was a guy who recommended the 'One Hand Operation +' You can have widgets in a separate screens that overlays your home screen...
Anywhoway..
Thanks for your help
Tracy
20-06-2022 09:03 PM
Hmmm.. Well that didn't last long..
I plugged the S22 back into the computer and it's back to charge only... Clicking on the 'Cable Charging' in the drop down down takes me to the Battery area...
Confused...
21-06-2022 03:14 AM
I've resorted to doing a factory reset on my phone, and... Same problem, will only connect for charging only. (USB debugging is checked and Transfer files selected...
21-06-2022 07:39 AM
Hi @Dragon_
Why are you activating USB debugging as that is not available unless you are activating the hidden developer options.
If you have the settings above as per my image and when unlocked you connect the cable it will automatically connect and ask you if you want to use Dex. The only reason this doesn't happen is if your cable is faulty or you've changed a setting.
21-06-2022 01:02 PM
Hi @Northerner
I turned USB Debugging on originally because the phone wasn't connecting to my puter.
As I was searching the internet for a remedy that wwould fix this issue a few sites and videos suggested enabling it.
But it doesn't matter whether it's enabled or not, the phone just won't connect.
In the notification area there is the 'cable charging', when you click that, instead of the 'transfer files, transfer photos, it takes me to the battery page..
I'm at a loss...
21-06-2022 02:26 PM
I also tried it with my other computer, and it does the same thing. (clicking 'cable Charging' takes me to the battery page)
