Sim connectivity issue
Rahembinahmad
Hello EE Support team
My name is Rahem ********. I need your help to check the network/blacklist status of an iPhone 15 Pro Max and, if possible, remove any block so the device can be used on EE and other UK networks. Let me know if anyone of you is having solution for this
[Mod edit: Please do not post personal information on the public board. Thanks!]
You can just apply for unlocking by using the Unlocking your device form and giving its IMEI no., which you can obtain be dialling *#06# into its keypad.
Northerner
Hi @Rahembinahmad
You can check a mobile status/history here: https://www.checkmend.com/uk/
