on 10-04-2022 11:27 PM
I am attempting to unlock my EE Buzzard 2 device using the code provided at https://myaccount.ee.co.uk/app/device-unlock
I have already attempted to unlock the device using the code provided on a couple of occasions, but the device rejects the code as invalid.
I also emailed [email protected] as advised on the above page, but haven’t had a reply.
on 12-04-2024 12:41 PM
Final email today from your support after confirming the IMEI and them reaching out to the manufacturer......
Hi from EE,
Sorry you have not been able to unlock your EE Buzzard Wifi device.
The manufacturer have advised that they have no other code available and that the Code ********
Should have unlocked the device.
Unfortunately we are unable to support the unlock any further.
Regards,"
What a shame that after 6 more attempts this will now be bricked and go to WEEE waste.
Any ideas?
on 12-04-2024 01:58 PM
Hi @Profile closed
I am very sorry to hear the manufacturer have been unable to provide a different code for you to try. It may be worth trying a different network SIM and entering the code, just to see if it works for you.
on 12-04-2024 02:00 PM
Thanks for the suggestion Leanne. I will try to do that and report back here my findings. 👍
on 12-04-2024 02:07 PM
Thanks @Profile closed
Leanne 🙂
on 11-11-2024 10:28 PM
Hi Leanne I’m having same issues just has reply from David who says he’s spoken to manufacturer and the code is correct and unable to help further
on
11-11-2024
10:56 PM
- last edited on
12-11-2024
10:29 AM
DanielPA
Just to let you know I ended up sending to a guy who unlocked and returned to me.
12-11-2024 11:06 AM - edited 12-11-2024 11:14 AM
Hi @Clarkcameron1
Sorry to hear of the experience you're facing, and thanks for keeping us updated with your unlocking process.
As the unlocking teams are unable to help further, you may need to contact the device manufacturer directly for unlocking support.
Ali
