02-07-2026 05:15 AM
I'm in the US, I scanned the QR code and it added the esim but never asked for the activation code it just automatically added it so I got confused. I figured I would remove the esim and scan the code again to redo the process and now it wont let me add the esim? What do I do? I'm arriving in London tomorrow and I can't figure out how to get technical support.
02-07-2026 08:13 AM
@Kyra88 Once a QR code is used it cant be used again. If the esim was added first time then it was added and you removed it. It would have worked when you got to the UK.
