Update on EETV EPG problems
zulu17
Star Contributor
Star Contributor
Any update please on when the EPG guide used by EETV boxes and the EETV app will become reliable. Several glaring errors with several of the Sky Sports channels yesterday.
28 REPLIES 28
DarrenDev
EE Product Expert
No update other than that the team have it as their number 1 priority - there are calls and reviews on a daily basis, and every error is flagged for explanation by our suppliers.
I understand the inconvenience it's causing you, and can only apologise - it's having major impact on our systems too, so we're just as keen as you are to make sure it's sorted ASAP.
DarrenDev
EE Product Expert
Latest update is that the cause is known, and plans are in place with our suppliers to upgrade their systems in a phased approach.  This will take a few weeks, with incremental improvements being seen as they go.
Until the upgrades are complete, systems are being closely monitored and errors being manually fixed as quick as possible.
zulu17
Star Contributor
Star Contributor
There is also a current issue with the TNT Sport Ultimate  channel EPG 433/465 as No information available seems to displayed after today. There are several upcoming football and rugby games that I would expect to appear in the schedule  starting with Newcastle v Barcelona  (discovery + does indicate an UHD stream is available)..
DarrenDev
EE Product Expert
We've been informed that major update took place yesterday, which has resulted in a 75% reduction in errors.  Our overnight tests confirm a significant improvement in data quality for the next 7 days.
Work continues to improve the rest ...
zulu17
Star Contributor
Star Contributor
Thanks for the update - certainly most of the EPG entries are in a more readable English format so on the surface significant corrections have occured.
I still get regular problems when trying to record NBA basketball on Sky Sports +. I'd say that 9 out of 10 attempts will fail to record, and on the rare occasion that they do, the end of the game is invariably cut off as the recording can't cope with any extension past the scheduled slot. I pay a lot of money for sports and hope that the issues are still being looked into?
@GreenGoblin72 I can see your recording failures - the recordings are being cancelled (marked a failed) as the series link on them is changing.  For example these 2 programmes on the 19th were originally scheduled together as part of the same series:
Live: NBA: Thunder @ Cavaliers: Oklahoma City @ Cleveland
Live: Basketball: NBA: Dallas @ New York
But the first one has been cancelled (and marked as failed) on your TV Box as the data now says it's part of a different series.  We'll raise it with Sky to ask why.. This is unrelated to the other issues being experienced.
That would be amazing if you could take it up with Sky for me. Thanks very
much for your help with this.
We've had confirmation that the series link between NBA programmes has been corrected - you may need to schedule your recordings again.  They've yet to provide an explanation of how they became out of step.
