12-09-2026 08:35 PM
Our Home Screen is not displaying apps & is saying they’re unavailable.
Tried rebooting the box & the hub but nothing has helped.
any suggestions please .?
01-10-2026 08:21 AM
Hi @Hocall1975
Please try to do a factory reset of the box to see if that helps. If it doesn't, I'd recommend giving our tech guides a call so they can look into this further for you.
Michael
13-09-2026 12:28 AM
Which EE tV box do you have?
Which display of apps are you referring to? Those that can appear near the top under the synopsis? Or those further down on the Apps row?
If you go into the Apps screen are they also missing from there?
On the home screen is anything else missing?
30-09-2026 04:02 AM
Mines is the same Fi I renewed my contract I do it with the box But I also need to turn TV off at wall for 2 Seconds
30-09-2026 09:45 AM
Welcome to the Community, @Jota88
Could you please describe exactly what's been happening here?
Has this only been an issue since an upgrade, or has it been going on for a while?
Does it rectify itself after a reboot too?
Peter
30-09-2026 05:28 PM
Getting no app coming up, rebooted box and modem. Tried another HDMI cable as well. Only get live tv.
01-10-2026 08:21 AM
Hi @Hocall1975
Michael
