Unable to factory reset
Yorkie064
I am having issues with accessing the App Icons and have tried a soft reset to no avail.
I want to carry out a factory reset but have same issue. When I press the home button I dont see any App Icons or the menu.
Anyone had similar issues and if so how was it resolved? Thanks
Midnight_Voice
@Yorkie064
What do you see?
Are you sure you are on the correct HDMI input to see the EETV display?
If so, hold down the On/Standby button on the box (not the remote) for just over 8 seconds until it soft reboots, and see if this helps.
