UK tv app channels
KP1001
Hi. Is it possible to add the channels on the UK tv app (Yesterday, Bravo etc) onto the general channel guide list? Have a family member who is unable to navigate channels via the app but can use the channel guide to search. Thanks
DarrenDev
EE Product Expert
Unfortunately not @KP1001
That's a pity. Will probably need to go back to viewing via aerial.  Changed over to digital because some of the channels were pixelating, but lost some of the channels in the process.
Thanks for the reply @DarrenDev
@KP1001 When the channels are pixelating or you want a channel in HD ie ITV2/3/4 use the appropriate catch up app as alot of the core channels allow you to stream the channels via their apps. Unfortunately the U app is not one of them though at the moment.
Not all catch up apps for the core channels have their live streams on the Pro box or mini boxes so I would suggest using Freeview play apps, fire stick, Google chromecast or roku apps for those.
I feel your pain with the lack of channels on IP mode though and it will probably be a deciding factor for some when their contracts come up for renewal.
EE Pro TV box, Full Fibre 900
For EE contact details see
https://ee.co.uk/help/contact-ee
Thank you @Weerab2024 That's useful to know.
