Reset password discovery plus
Bluesriff7
I need to reset password for discovery + ?
then use my new password to sign into HBOX
DarrenDev
EE Product Expert
If you need to reset your password for discovery+, then visit discoveryplus.com and request a password reset.
If you need to reset your password for HBO Max, then visit hbomax.com and either reset your password, or choose the option to "Get one-time code" which will email you a token to log in instead.
DarrenDev
EE Product Expert
Bluesriff7
All sorted thank you
