22-07-2025 07:06 AM
Hello, first morning of using EE Tv and there is a privacy policy notice but I can’t get the dismiss button to highlight to dismiss it. The remote works for the sound etc but appears to be stuck on this notice. At a loss as to what to do next. Thanks
22-07-2025 12:39 PM
OK, so the good news is that rollout of a fix has already started for this issue. Please leave your TV Box turned on overnight tonight, and you should find that the message is gone in the morning,
Sorry for the inconvenience.
22-07-2025 07:09 AM - edited 04-08-2025 12:14 PM
*editing out irrelevant comment to avoid confusion*
22-07-2025 08:17 AM
Thank you. We used the WPS button so I don’t think we can be on the public network?
22-07-2025 08:51 AM - edited 22-07-2025 09:19 AM
*deleting my previous reply*
@Vichu1 has updated me on a known issue that is more likely to be what you're seeing. The only known workaround requires one of our old TV remote controls, which I'm guessing you don't have? We're investigating to see if there's another option.
22-07-2025 08:53 AM
Hi @Jules020676 ,
Please could you send an email to [email protected] with snapshot and we would be happy to assist you with this. Thank you.
22-07-2025 12:39 PM
22-07-2025 05:31 PM
It looks to have disappeared so at least we can watch TV tonight. Thank you for all of your help
02-08-2025 08:39 AM
Hi DarrenDev
I've encountered the same problem and leaving the box on overnight didn't help. I think it turned itself off as not being used. Do I have to leave the telly on as well? As a new EE customer this is really unsatisfactory.
02-08-2025 08:59 AM
@Don381 I'm a bit confused by your account, as I can only see a TV Box Pro on it - this issue only affects the TV Box Mini (as far as we know).
If this affects a TV Box Mini, can you please share the serial number? There's not one showing on (or connected to) your account. If it's a Pro, then we have a bigger issue to address!
02-08-2025 09:16 AM
Hi Darren
It's a TV Box Pro that's causing the problem, so we need that solved.
However, we have two TV Box Mini's for extension of our TV's to other rooms that we have not yet connected.
Don381
