on 03-01-2026 03:58 PM
I regret to post this and will remind those of the parameters deliberately removing the post and the reality requirements if Dunstone for what reason just to hide scenarios but I continue to have my services my contract my ownership and my accountability of identity fraud manipulated and blocked from being registered correctly for those that stupidly attempt to account for producing my data being me and movements around me whilst at the same time try and target me with that data accusations of criminal behaviour and inappropriate behaviour trying to cover and surround every angle possible to target made to a detrimental position. Author money basically my inheritance of birth
Engineers turned up to my property but unannounced times non-specified times by other members of staff over the phone give a whole breakdown of service that they’ve given and then learn to hold post it somewhere because it has to touch the system for record i.e. on an apparently closed for band account which isn’t and my current open broadband it should’ve been both because I requested two I’ve got two separate properties but never somewhere that’s laid forward and straight for me to check on that and the application is almost non-operational all the time to prevent me from using the security services installed
So the situation breakdown is the master router for Openreach so the connection has been installed in the wrong property upstairs upstairs then all of the connections of my contract as well as Maya relationship with EE and who I am he’s being connected to an unregistered point from AB which is a service services distribution point and B the contracted legally owned personal question and their property for services yeah my wiring connectivity you know the way to get connected is not running the principle of a to be instead it’s going in your property which is not where I live. I live at ground floor flat and then it’s coming down to me so from point of connection to the service going in someone else’s property, then finally coming into my property where it’s connected to be I’ve raised numerous reports numerous concerns to which I’m **bleep**ed off or they try and give me excuses or the last person that tried to give me an excuse. Let me send you this and let me send you that so they sent me a breakdown of what they can see on the network for connected stuff after proceeding to get me to disconnect all my devices clearly because they were scared or irritated I really wanted to cause affect and then sent me a secondary drawer of what they could say on the network but they were negligent to stay or notice that you can clearly see two connections to separate account accounts of SP network one connecting second not connecting on a moment the second account has been closed isn’t it? No on paper proof it’s still open. it’s still active I cut the fibre optic cable in to my fibre ball which means it shouldn’t connect so straight away it says SP network back up connectivity not connected but on the top one it connects straight to the hub pro
so now my concerns are you violated the contracts? You violated my privacy? Do you violated my home? You violated my reputation and the people that you are supplying my stuff which is my connection my network my business to haemorrhage mass amounts of money how are you gonna fix that? How are you gonna tell me? Oh we’re very sorry and fix it because I effectively can’t do nothing, effectively or safely under the parameters of feeling comfortable and secure to do so with such a level of compromised position this is the last time I will attempt to be heard before I have this dealt with and proceed forward because if I have to proceed forward, I will represent myself and I will show you how smart clever decent appropriately correct and incredibly astute when fundamentally it comes to licensing law and policy
Solved! Go to Solution.
on 03-01-2026 04:11 PM
You can complain here: https://ee.co.uk/help/contact-ee/complaint
Good luck.
Good luck.
on 03-01-2026 04:28 PM
@LordMasterNGBD Do a complaint your Forum posting is a waste of space and not communicating with EE!
on 03-01-2026 04:31 PM
@LordMasterNGBD : Incomprehensible!
on 03-01-2026 05:59 PM
@XRaySpeX wrote:@LordMasterNGBD : Incomprehensible!
At least they've used paragraphs! I've known new posters to be in a similar rant mode and not bother with any punctuation.
on 03-01-2026 06:55 PM
@bristolian : Very true! Their paragraphing is impeccable. Pity about the sense..
on 03-01-2026 09:04 PM
Has anyone figured what’s it’s actually about yet ? I know it’s something about broadband but that it.
03-01-2026 09:20 PM - edited 03-01-2026 09:24 PM
Maybe 2 BB lines at diff locations, maybe 2 flats in same block, maybe one doesn't work & the other does as long as OP has not sawed thro' the fibre as he claims.
Resulting in a claim for Consequent Loss which, of course, EE contracts do not cover.
Well, that's my sum total take on it!
on 03-01-2026 09:25 PM
@Chris_B If he is a Scotsman like me coming out of the two day holiday hangover is a possibility and the rant is over Fibre connection and setting up i think or wishing to take on all the EE lawyers they can muster in the one room, not going to swear to that though!
on 04-01-2026 11:23 AM
@JimM11 I got lost when they had to fight the giant octopus. ( if you know you know ) haha.
