New to EE TV - requesting a second box
MarcusPos
Have been with EE TV for a month or so now after 27+ years with Sky and am rather impressed so far.
Is a second box for upstairs free or chargeable per month, as have read conflicting discussions??
Cheers for any info 😀😀
DarrenDev
EE Product Expert
There have been various offers in the past, but it's not free anymore.
DarrenDev
EE Product Expert
MarcusPos
OK, cheers, do you have to ring up to request one or can it be done online?
Call EE CS on the Freephone no.(Opt 1) in my sig. to order it.
widdowsonben
Skilled Contributor
Skilled Contributor
Hiya Marcus
I'm not sure what box you have at the moment but multiroom via EE is very different (and less advanced than you would have had with SkyQ/Stream). The second and third box (they limit you to 3 still at the moment) are all non-recordable. There is no planner sharing so the multiroom box can't access recording on the Box Pro (if you have that). There is also no option of having a second or third Apple TV (really annoying).
EE / BTTV user since BT Vision - EE FTTC (Smart Hub 7 Pro), EE TV (Apple TV).
Starlink for a backup.
l1feways
Valued Contributor
Valued Contributor
Wow if you think the EE muti room box is the equivalent of a Sky puck then boy are you in for a shock
It's £10 extra monthly for a primitive freeview stream only box
Way better and cheaper getting a firestick
