on 19-11-2024 10:51 PM
This afternoon I switched on the TV Box Pro and the TV using the remote as normal. It came on OK on channel 3, which I had last been viewing, but with no overlay of information. The only buttons on the remote which give any response are the volume control, the mute button and the input selection button, which can be changed with the central control. The on/off button now only switches the TV off or on. It does not switch off the TV Box. I have tried resetting linking the remote (Home + 9 and Home + 7): No change. I do not fully understand the instruction for resetting the box. Found button on end of box, but not the power button. If this is the roughly 1 inch square panel on the front of the box, it does not seem to move. In particular, holding the Home button does NOT bring up the control screen on the TV. Before I contact the technical team, does anyone have any experience of this? or any tips to cure it? I don't want to be restricted to watching ITV for the rest of my life!
Solved! Go to Solution.
on 20-11-2024 12:45 PM
on 20-11-2024 12:03 PM
Hi @Jackdawing
Could you try resetting the TV box by unplugging it from the mains for 30 seconds or so please? Let me know if that helps fix the problem you have with the remote.
on 20-11-2024 09:31 PM
For future reference, the one inch square on the TV Boxes is the IR window.
It cannot be depressed by EETV customers; though EETV customers can be very easily depressed by their TV Boxes.
on 21-11-2024 03:09 PM
What does IR stand for? The only thing I can find is Infra-red, which does not seem to apply here.
on 21-11-2024 05:19 PM
You got it, it’s Infra Red.
While these boxes have Bluetooth remotes, they still have an IR sensor to respond to traditional IR remotes, and will continue to, even if they have been paired with a Bluetooth one.
on 16-12-2024 04:28 PM
Hi. I'm new to this too.
On/off button on front is the ee motif in blue not the inch square you mentioned. Sorry can't be more help .
on 16-12-2024 05:13 PM
Thanks. It made itself obvious by flashing at me! All sorted.
