26-06-2024 11:22 PM
Just changed over from sky tv to ee. We have been given a mini box for another room with our subscription. We’ve set it up but when we click on the channels just says we need to set up HD channels . We’ve already set up the ee pro box downstairs so why can’t we watch normal channels on the mini box? Seems a waste of time because most of the channels show as HD yet show the same message yet I don’t understand what I need to set up.
29-06-2024 07:42 AM
It’s now just continually loading can’t back out of it seems stuck. I’ve unplugged it and tried again and same thing. What a load of rubbish this is. Glad it was free and that I’m not paying for it
29-06-2024 07:51 AM
That's definitely not a normal experience. Can you please confirm you have it connected directly to the EE Smart Hub, and not via any of your own home WiFi equipment? It'd also be worth trying a factory reset of the box.
29-06-2024 08:05 AM
I’ll try a factory reset
29-06-2024 08:18 AM
The reset has sorted it I think
29-06-2024 08:30 AM
Ok that's great. Sorry that it didn't work first time. Let us know if you have any further issues.
29-06-2024 08:34 AM
Will do thank you for your time
30-06-2024 02:24 AM
30-06-2024 02:24 AM
24-08-2024 10:54 PM
Does the mini box have to be plugged into a router. It’s not connecting to tv upstairs via wps! Can I change back to sky with no issues this is ridiculous
25-08-2024 09:04 AM - edited 25-08-2024 09:05 AM
It needs to be within 5 metres of your router, or a repeater, but it should be able to connect by WiFi if so. Though have you got very thick walls?
But it’s your router it should connect to by WPS, not the TV, which it connects to via the supplied HDMI cable, though. (Which is what I think you meant to say).
