Mini box apps
BabyManatee
Valued Contributor
Valued Contributor
I've received my Pro and Mini boxes ahead of my switch to EE next week ( hopefully, but that's a different story).
I positioned my boxes and connected them up ( no ariel to the Pro yet), connected my existing WiFi and successfully updated the firmware. But I noticed that the mini box doesn't have the ITVX or Channel4 apps(which are available on the Pro), but does have iPlayer, Ch5, Netflix, Prime, Now TV, Paramount, etc.
Is this correct?
I've trying searching a list of apps that should be installed but with no luck.
11 REPLIES 11
zulu17
Problem solver
Problem solver
Currently the apps I would expect you to have are
plus  a couple of Free Games  appsand the Hep App if you scroll down.the image .
The EE  TV app will probably not be present until you are connected to EE broadband.
The image (which would need approval before it displays) is taken from a current EE promtional webpage
Service activities but no change. Did a factory reset and the apps appeared
