Low signal quality ee tv pro box
Ianhutson08
We are experiencing low signal quality on the tv pro box (both boxes we have been sent) and our previous bt pro box too. Signal strength is good, around 90 to 100 percent but quality is poor at around 20 percent (max 30 percent)
The odd thing is that a bt engineer left me with a bt 4k uhd box and with the same cables and set up it shows 100 percent quality on every channel. I have tried an old youview box which also shows 100 percent quality.
Pulling my hair out as to why the pro box would be giving such poor quality vs the non pro box.
Ian
27 REPLIES 27
Timbo45
Expert Contributor
Expert Contributor
@Gracewillis
Do as was earlier suggested and get a variable attenuator fitted between the box and the aerial feed and reduce the strength to around 85%. This should help.
I don’t understand why I have to pay for something more when I’m paying for the service already and my 10  year old box works perfectly?
Timbo45
Expert Contributor
Expert Contributor
@Gracewillis
I understand what you're saying but equipment suppliers can't always cover every eventuality that might be occur.
Having said that the tuners on all the BT/EE TV boxes have been incapable of handling very strong signals that overload the tuners. The solution of a variable attenuator fortunately is not an expensive one , costing maybe £8 - £10.
I had a look on amazon but have no idea if I’d be ordering the correct thing. I’m going to give EE a call tomorrow as I don’t really know what I’m doing. It’s frustrating how a 10 year old box can perform but yet a modern box cannot
my contract with talktalk has been up for 18months and I had avoided switching for this exact reason…….. a problem and something not working
Thankyou for your help
 Is this what I’d be needing to get?
Leanne_T
Morning @Gracewillis
Thanks for posting on the community.
If you give us a call the team will take a look into this for you and see what is needed to help with the TV signal quality.
Let us know how you get on 🙂
Timbo45
Expert Contributor
Expert Contributor
@Gracewillis
That's exactly what you want.
edbostan
When I subscribed to BT/EE TV I had the Humax DTR4000 box which was replaced with the Sagem Pro box. Signal quality and strength were both 100% but the Sagem box gave, in my view, a softer picture.
