16-10-2024 01:07 PM
Hi, can anyone help with a sound issue. Sound is fine until after an advert while streaming on Discoveryplus. Sound then goes off. I can switch to other channels and sound is fine. Then switch back to Discoveryplus and sound is fine until after the next advert. TIA.
16-11-2024 02:37 PM
@Alex_H Thanks for this Alex I will give it a try.
16-11-2024 03:51 PM
Hi All,
Just come off the phone with Leanne at BT support, don't think it was @Leanne_T as she had never heard of this issue before. Anyway after much restarting, checking network, software version, apps version and such she went off to contact more technical support gurus who told her this was a known issue with the Discovery+ APP that EE couldn't fix but they were working with Discovery+ to find a solution! I did tell Leanne that like @BeckieBDE I'm sure the sound issue has happened on other APPS (maybe NOWTV) but I wasn't sure. Anyway the advice was to either do what I have been doing (press BACK then OK to resume the programme) or watch Discovery+ on my Fire TV stick!! I will do some tests on NOWTV with the EE Box vs the Stick and keep you all posted.
16-11-2024 08:08 PM
20-11-2024 04:09 PM
I'm having the same issue. No sound bar connected and it's only on Discovery plus.. very annoying. Is there any other quick fixes suggested without having to read 5 pages of answers? Many thanks in advance.
20-11-2024 04:42 PM
Hi @lunabells, Think you will find there are no quick fixes in the preceeding posts other than when the program restarts with no sound after the ads press BACK then OK to resume where you left off. Alternatively use a Fire Stick or other streaming device/box!!
27-11-2024 10:17 PM
I’ve got the same issue, box and apps up to date, brand new tv, I’ve still got an old BT box so might try that
28-11-2024 08:57 PM
Newbe here. Had EE Box a month swapping from bt which i had no problems with.. Samsung tv with soundbar and we lose sound after some ad breaks, but not all, on Discovery plus.
If I rewind 10 seconds and then press play we see the last few seconds of the show before the ad break, then it carries on with sound.
It seems this is an EE problem that they aren't addressing even though it seems to be common.
I don't intend faffing about swapping hdmi leads I'll just wait for a software update to happen.
I'm just joining this forum to add my two-penn'orth.
28-11-2024 09:15 PM
Just to add my bit..definitely not the bt box or hub or Internet, my Samsung tv has the discovery app and it does the same thing as soon as the adverts come on the sound goes off. Tried updating everything and still the same just have to go back and restart the channel I was watching. Tried it on all the tvs with the app and all the same so I think it's definitely the app at fault.
07-12-2024 07:35 PM
Another frustrated user who has noticed this issue since my BT TV service migrated to EE TV (still the original BT box), but not after every set of adverts.
Hitting "back, followed by "resume" restores the sound and then we wait with baited breath for it to happen again!
15-12-2024 09:23 AM
Hi . The same happens to me and I don’t have a sound bar. Did you happen to find out the answer?
Thank you
Jenna
